EMU PRO base map for Subaru EJ20 VVT
EJ20 VVT (intake and exhaust) stock engine setup, swaped into the Legacy chassis
Description
Base Map
Scope
Log
Inputs and outputs assignment
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
