Fully tuned for the stock engine.
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
