EMU PRO base map for BMW S65B40
Fully tuned for the stock engine. (Sequential gearbox)
Description
Base Map
Inputs and outputs assignment
These baseline maps provide a starting point for tuning and are designed for specific engines. They are not guaranteed to work correctly out of the box and may require adjustments to fit your particular setup. Always treat these maps as a foundation to build upon and make further refinements as needed.
